Grate write up from the event. I have been hanging to read all about it as I refuse to use Facebook and people only seem to talk on there, otherwise you wait months to watch it on DVD.
Do you think that not running any form of bov has caused the turbo failure? I know most people diss like them but a $50 part may prolong a $1500 part. I fitted one after my Garrett shit itself.
One thing that worries me doing a mainland trip is having something go wrong with the car. You can't carry a whole cars with of spares.
Keep it the good work.
well ADGP happened... theres a full write up of the drama's that i had along with pics on my website
http://www.smdrift.com.au/1/post/2012/06/adgp-round-2-wrap-up.html
after the box blew i went thrashing... not a single f**k was given
I can't believe you blew up a 25 box, that mustn't happen every often? also what killed the turbo, just extended high temperatures cook the bearings/rear wheel?
Sucks to have two major things go like that, sounds like you have a blast either way though!
Edited by Rolls
time for an update... first heres some pics and vids from calder.
in car of Ben purtel.. thought it was a good vid cause it really showed the speed of it all and the amount of smoke my car generates haha
another shot with me and Andrew Constatine from Tas... this was during prac session sat morning before my turbo blew. chased him 3 times like this.. first time i tagged his rear bar and you can see my corner light is missing as a result haha
Update time: prepping for WTAC mainly.. that will be the next outing for the car. Diff is getting overhauled and new 4.3 gears. the New motor set up struggles a bit to turn 4.1's with sticky tyres which is why i blew 3rd probably. need an overhauled gearbox and then the motor is probably coming back out for a full check over also. fun times ahead.
i usually run 255/40/17's in Achillies ATR sports or Federal 595. for calder park i tried some of the new Achillies 123s in 265/35/18 pressures usually around the 25/30 psi mark but i actually had to run the 123s higher at 45 psi just to get a decent drift going.
the amount of grip and speed with the 123s is huuuuuuge!
VQ30 would be pretty cool though. But need a lot of attention to intake and exhaust manifolds. They are f**king mess.
Although VQ35 shit would bolt on and strokers, cams choice is abundant. With a really big 6-speed VQ35 gearbox.
It would be indestructable drivetrain. Not sure about the engien though.
You could get a VQ35 gearbox bolted up to RB, Simon. Won't be very difficult and that gearbox is huge. RB or JZ Getrag looks like small kitten near that monster.
Also + for better weight destribution with VQ30.
Edited by robots
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
