Got any runs of the 3 buddy drift with monkhouse and the blue ute?
That was the highlight of the weekend, actually was some of the best drifting I have seen. Looked mint
none of my cameras captured that run sadly... someone filmed from the crowd tho.. can be found on my page if you have a look.
http://www.facebook.com/video/video.php?v=109807555839205
Not sure if I missed it but how did you hook up the accusump - did you use the electronic solenoid or just hook it up directly so it's constantly filling and discharging?
You put on an amazing smoke show at wtac btw!!
Cheers dude!
accusump is as easy as possible.. no elec solenoid,. the sump is sitting behind the drivers seat and handle is accessable from the seat, i have it covered as per cams regs. Braided line goes down the transtunnel and hooks up to a T piece on the oil relocator kit in between the block and the oil filter
when motor is off the valve is off so it has a storage of oil for when i start it next time, when i start it i open the valve all the way, start it, let it warm up and bleed any air out then close the valve to half and thats where it stays for operation. the reason behind the half valve position is because we found that it was discharging too quickly fully open and then taking too long to fill up.
Every set up is different.. I did some data logging with valve set in different positions before I found the best one that worked for me.
Ill get some pics up soon of it.. Enclosure is nothing fancy lol just a rolled sheet of alloy
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
