Well I am starting the saving process to make an order so that hopefully by year end I can have everything needed for my upgrade. Here is my base and what my plans are and let me know what you think of it.
Base:
ER34 RB25DET Neo - pretty much stock
NGK Iridiums BKR7EX-11 gapped to 0.8
HKS FMIC
Trust 13 row Oil Cooler
Two Core Radiator
Kakimoto 3.5" Exhaust
Blitz ECU
Blitz SSBC
Blitz Timer and Gauge
Trust Air Filter
Defi Boost, Oil Temp, Oil Pressure, Water Temp, EGT
Plans:
HKS Bottom Mount Manifold - Actually Have this already
GT3076R 0.82A/R with four bolt turbin housing and V-band add-on
External Wastegate - Not sure what size to go with and also what alternative can I use instead of the HKS that will fit properly on the manifold? I am thinking like a Tial 40mm, your thoughts??
Spare head with the RB26DETT ITBs and Intake Manifold setup - Help eliminate the pipe running over and also a better look same time
Keeping the TCS
RB26DETT 700CC Injectors with HKS/Tomei/Sard Fuel Rail and Resistor pack
RB26 Cam Cover and Center Plate - Bling
Keeping VCT Solenoid
Oil Return from Head
Cosworth Headgasket
Tomei Restrictor and block off as well
ARP Headstuds
Clutch ?????
I really don't want to get in the block if I do get some extra cash and I get an entire spare engine I will get the collar attached to the snout, freshen up the block with bearings, ARP mains and ARP rod bolts also try to adapt the RB26 sump as well. Can I get your thoughts on the setup and also what clutch recommendation for a daily driver that will be at some points be in standstill traffic and on hills as well, not looking for something aggressive but able to handle 450HP. Also, what wastegate option? My management will be a toss up between the Vipec and the Power FC, the Power FC being so expensive now I may swing the Vipec way. Please no bashing on the management but on all other aspects feel free :dry:.
Well as can be seen, I already have the HKS low mount mani, can I get the 3071R T3 flanged and also externally gated? Really don't want to block off the flange and I already have it so wanna use it. Also do I have to worry about clearance issues with the ABS setup and also my engine mount?
high flow or 3071, id think the 3071 would have abit more kick, even though they have the same output rating, cheaper than a high flow
anyone know what parts need to be bought to fit 3071, oil/waterlines/dump/manifold
Edited by Dorifta
So sell the manifold.
What does it matter if you have it on there or not?
You can get a GT3071 in external gate form as it comes from the same turbine family as the GT3076.
I would stick with your original plan and go the GT3076 there is no need to wring the neck of the turbo to make your power target and you will have some headroom if you want with minimal penalty.
If you have a HKS cast manifold (divided) I would use it as it opens up the possibility of using a T3 flanged twin scroll turbine housing like ATPturbo.com sell. You are going to need to fabricate some exhaust and intake bits to make it fit anyway so it makes little difference if you change manifolds at the same time to a superior option (since you have it on hand).
IMO wrong turbo for 450hp as you stated.
Too big.
You want a 3071, and then you don't need external gates either, a lot simpler and will make the 250-260rwkw which is your 450hp
What u smokin bro?!?
Last time i checked 450hp was more like 335kw so the GT3076R should do it ....but with lots of boost!!!
Send Rhinorebel on this site a PM, he has the exact set up you mention, It is very responsive and makes solid power, im sure he can shed more light on his experiences with the set up and any potential problems (he had a few along the way)
Hey buddy. Call Jeff at Marine International Diesel (MIDI) in Ft Lauderdale florida (tell him justin sent you). He's a Precision Turbo dealer. He also runs around the carib/islands alot. I just bought a PT5557B for under 1k. It's rated at 550 odd hp, garret based, billet comp wheel, T3 flange, V band dump flange, external gate turbo... Great value!!! Jeff also has a MEAN R33GTR with a large Precision Turbo.... awsome!
You can always mod the manifold to fitt up the turbo and/or wastegate.
rwkw vs flywheel
not that ash needs help defending since what he wrote allows for drivetrain loss.
Keeping the TCS
Cosworth Headgasket
ARP Headstuds
Clutch ?????
I really don't want to get in the block if I do get some extra cash and I get an entire spare engine I will get the collar attached to the snout, freshen up the block with bearings, ARP mains and ARP rod bolts also try to adapt the RB26 sump as well. Can I get your thoughts on the setup and also what clutch recommendation for a daily driver that will be at some points be in standstill traffic and on hills as well, not looking for something aggressive but able to handle 450HP. Also, what wastegate option? My management will be a toss up between the Vipec and the Power FC, the Power FC being so expensive now I may swing the Vipec way. Please no bashing on the management but on all other aspects feel free :mrt:.
The ARP mains and head studs are pointless for your power goal. and the 26 sump has nothing of benefit to offer unless you are converting the car to 4wd.
what are you going to use the car for?
if you are going to track it hard and often, then go the restrictors, and arp bolts while you are in there anyway... but if its just a streeter that sees the occasional light hearted track day, then there is no need.
i'd go a 3071, and a set of cam gears and keep good response while not risking the stock internals too much
Just sent him a PM to see if he would respond. I thought the GT3076R would be better as 3071R will be at it's limits. The cams may come later on but for now that is what I am thinking of. The twinscroll was always an idea for some quicker spool as it is a twin scroll mani. Thanks for the inputs and keep it coming. Also what is a good street clutch for my application that is nice on the left leg?
nismo supercoppermix twin plate
if you are 100% doing the 26 top end then you'd be stupid not to do the restrictors, so ignore my post.... i kinda just skimmed over the first post...
good street clutch? Super copper mix is awesome but $$
Jim Berry, NPC or Direct Clutch will make to order (ie power level, type of motorsport, etc) and at very reasonable prices.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
