I recently took my car into a mechanic to get a very slight coolant leak at the back of the engine checked out only to find out that i have a blown head gasket and the said mechanic didnt want to touch it as he was unfamiliar with the engine. As i have my car up for sale i don't want to sell it as is or do a dodgy on it so who would you recommend around the southern area to fix this. I was thinking Boostworx because i would like it done properly. any other ideas? IS this a common and expensive job? What should i be looking at paying roughly?
Basically the leak is coming from the very back of the engine and dripping down onto the gearbox. I can smell coolant after i have been driving but its such a slow leak that it never reaches the ground. I only notice a slight drop in the coolant level after a week of driving. The engine itself runs perfectly.
Any help would be appreciated.
Dan
Edited by Muges180
https://www.sau.com.au/forums/topic/291454-blown-head-gasket-repair/
Dan
Are you 100% sure its a gasket? Sounds like one of the hoses leading to your heater core has split. I had this same problem earlier in the year. Will cost a bit in labour depending on your engine and how easy it is to get to said hose... If your gasket had deteriorated you'd probably be finding a bad color in your exhaust due to coolant in the cylinder head...
Boostworx or John @ Southern Hitech can help you if you're down south, Gil @ Road & Track can do it if you're up north
-D
You'd know if it was the head gasket... milky shit under the oil cap, bubbles in the radiator when you take off the cap, etc.
Sounds like a hose to me. And head gasket repairs aren't cheap...
Exactly.I found the same thing the other day, just a hose. the oil is fine and the radiator isnt bubbly.
Ive located the fault hose after a bit of searching, jus gotta replace it tomorro
picture the very back of the rb25 between the firewall and the block. thats where its leaking from but i cant see exactly where its coming from because there is no room.
yiap definately sounds like heater core/hose leading to heater core
-D
I would hazard a guess and say its your coolant line from behind the inlet manifold, which runs around the back of the head, to the turbo. If the engine has ever been removed, chances are the pipe might have been crushed by the firewall (and subsequently a leak forming), or its simply the hose section right near the inlet manifold. Either way, its a bitch to get to (read: impossible). Removing the engine might be required.
Not necessarily.
the coolant isnt discoloured at all. The mechanic did a preassure test on it and said it was the gasket but im still not overly convinced. might take it into Shaun for a second opinion.
The facts so far:
Coolant leak at back of head.
Coolant level goes down in a week.
Pressure test confirms coolant loss in system.
You can have coolant leaking from a head gasket without it affecting your oil if the passage of leak is directly from an external water jacket....they don't always track to an oil gallery so oily radiators or milkshakes in cam covers aren't always present with blown head gaskets.
The other thing to check is whether exhaust gasses are entering the coolant system but then again, leaks don't always track between combustion chambers & water jackets either.
im no expert, but had this happen to me twice. no real warning (temp didnt go thru the roof, no milky residues) but a distinct smell of coolant and a lack of coolant after a few days / week
i think flick had the same trouble with her 32 when she had it too. doesnt bring the temps up to higher than normal temps until theres no coolant / water left in the system
thatd be the first (and less expensive) option to get checked. if those hoses are fine then it'll be the gasket
/2c
ive changed that hose twice now once on my sons car and once on my own first time took me a couple of hrs and the second time less than a hr .
the second time i used a pair of pointy nose pliars about 12 inches long and that made the job a shit load easier . still not a pleasant task at the best of times but buggered if i would pull a motor just too do it tho
Just what I was thinking.
Can you get a small inspection mirror down there, like what a dentist would use?
Not necessarily.
The facts so far:
beat me to it. i have a bore scope if you need to use?
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
