Hey all, got a few things that need to find a new home.
All have come off my 97 R33 GTR
All parts have been removed from vehicle
1) Standard RB26DETT Turbochargers, these will come with standard manifolds and dump pipes
Price $300 for Complete Set Up (please note that o2 Sensors will be included with turbos)
2) Standard RB26 Exhaust Manifolds, these are off my old R33 GTST R32 RB26 motor
Price $75
3) Standard R33 GTR Catback Exhaust, if you havea GTST this will bolt up aswell, if your having trouble with the cops for Db levels this will get you out of trouble
Price $150
4) Standard R33 GTR Front Mount Intercooler, these are pretty good units. If your after the sleeper look (being black and all) this is the thing for you
Price $150
5) Apexi Power FC for R32/33 RB26DETT, conventional power fc. As new condition. Includes hand controller aswell. Selling due to Vipec upgrade
Price $850 Delivered
6) Trust MX Front Pipes, these make a huge difference in terms of reducing lag even on the standard car. This is no longer required on my car, no holes, minor scuff on one of the pipes
Price $200 (postage can be negotiated into price for non local buyer)
6) Factory RB26 BOV, awesome BOV's would retain them however space is at a premium.
Price $80ea or $140 for both
Also the complete plumback assembly is available inquire within for details
7) RB26 Sump Modified to suit RWD, mod carried out by Advan Performance. was only on my old GTST for around 13000 km comes with all baffles etc
Price $350 plus postage
I will most likely have more parts that will pop up, will hopefully get some pics up tomorrow for you guys
Best contact would be via txt on 0404585529
Cheers Marty
Edited by Weapon
https://www.sau.com.au/forums/topic/291553-r33-gtr-parts/
turbo chargers are $300 both or each?
whats the model of them?
$300 for the pair, inc dump pipes, o2 sensors and the snouts to meet up for the intakes
These came off my 1997 R33 GTR
Cheers Marty
https://www.sau.com.au/forums/topic/291553-r33-gtr-parts/#findComment-4874532
any ideas on postage to perth?
Not to sure mate, if you shoot me a pm with your area code i'll do some calling around tomorrow and see what i can find out for you mate
Cheers Marty
https://www.sau.com.au/forums/topic/291553-r33-gtr-parts/#findComment-4874582
  • 3 weeks later...
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
