  • Replies 14.2k
Car is all back together to how it was, Just minus the cage.
Not to bad for a 4day turn around.
Fair effort man :thumbsup:. After my first defect on my old VLCT I had getting that back to regency spec down pack aha, ended up getting done 7 times all up in the time I owned that car - All of which were regency 6 of which were because cops were bored 1 'may' have been well earned haha. New owner hasn't had any troubles what so ever with stickers, and he has done almost tripple the k'z in it in 8 months then I did in 1.5years ffs
heckler gets owned
While that was good, I don't think it can ever top Bill Hick's going off at a heckler...
http://www.youtube.com/watch?v=7j7wmTEb4a8
The quality of the video is shit but this is one of the all time legendary Bill Hicks clips..
Starts around 2:30 lol
"What am I, a f**king jukebox? 'Put a quarter in his butt, push A-12!' "
-D
i found this one amusing
http://www.videosift.com/video/Chappelle-s...y-sings-Fu-k-it
mmm link no worky will find another one
once clicking the link, you have the remove the "**" and put "uc" in there.
Funny Video
damn it
my aem f/ic-8 wont flash - cant read/write, so needs to go back to usa factory
grr damn
car has been at the shop for a week only for this to happen. grrr
safc goes back in for a while longer
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
