  • Replies 14.2k
Car is all back together to how it was, Just minus the cage.
Not to bad for a 4day turn around.
Fair effort man :thumbsup:. After my first defect on my old VLCT I had getting that back to regency spec down pack aha, ended up getting done 7 times all up in the time I owned that car - All of which were regency 6 of which were because cops were bored 1 'may' have been well earned haha. New owner hasn't had any troubles what so ever with stickers, and he has done almost tripple the k'z in it in 8 months then I did in 1.5years ffs
heckler gets owned
While that was good, I don't think it can ever top Bill Hick's going off at a heckler...
http://www.youtube.com/watch?v=7j7wmTEb4a8
The quality of the video is shit but this is one of the all time legendary Bill Hicks clips..
Starts around 2:30 lol
"What am I, a f**king jukebox? 'Put a quarter in his butt, push A-12!' "
-D
i found this one amusing
http://www.videosift.com/video/Chappelle-s...y-sings-Fu-k-it
mmm link no worky will find another one
once clicking the link, you have the remove the "**" and put "uc" in there.
Funny Video
damn it
my aem f/ic-8 wont flash - cant read/write, so needs to go back to usa factory
grr damn
car has been at the shop for a week only for this to happen. grrr
safc goes back in for a while longer
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
