Jarrad, what side skirts are those? N1's?
And Wayne, as Damo said, chicks love the live read-outs. I bought a ECUtalk LCD read-out thingo purely for this reason. Not only do the chicks love my centre console gauges and love hearing me crap on about oil temperature, they also love reading vital information like fuel injector cycles. And water temps.
They love it.
I also indulge in explaining my torque metre in the dash.
But seriously, I hate it when chicks are like "z0mg you've got a Skyline... my ex ex ex ex bf owned one but it was like all square shaped." and you're like "but this... is a GTR... how can you compare that with a 31?" and they're like "but all Skylines are the same?"
I've only met a small handful of women who are like "Ah... GTR... 2 turbos then, eh?"
Reminds me of the time my girlfriend had a work drinks night at Marble Bar and some guy was talking to her. He's like "I drive a Skyline". So she replied "Oh which one?". He goes "An R31 Skyline". She follows up with a "Oh, the old shitty one? My boyfriend has a R32". He just walked away..
  • Replies 14.2k
lol hence why they dropped the skyline part off the R35. getting your 160k+ car talked about like its a 2k old pos.
I always note what they say as to how much they know, if they know nothing about cars they call it a nissan, a lil they call it a skyline, and if they know what a gtr is theyll call it that or godzilla or something
n n1 sideskirts drop at the rear wheel in a lil point sorta of thing aside from that they pretty much flat like a stock gtr side skirt, take a look at the calsonic R32 that has em. least thats what i think the n1 sideskirt is
Edited by Inline 6
All I know is its a standard GTR kit. I don't have the rear pods, but I think they're a factory extra
The sideskits you have definately aren't standard GTR kit, theyre type M's. Front bar is, and the rear pods look stock too (like dan says, the n1 has a lip that drops down, however it does look bigger than my pods).
(I'd love to get a pair, anyone got a link as to how much they cost?)
This is what stock r32 gtr side skirts look like
-D
Edit ; I see u edited ur post talbo, but I'd recommend Andrew at Goodyear on North East Road in Hampstead Gardens. Dude knows his stuff and has a 4 wheel aligner.
The place on Hancock rd opposite St Agnes Shopping Centre, fark the name escapes me!
Cheers. I know the place you're talking about but I don't live that way anymore so I'm going to just stop past somewhere on the way home from work and see if they can fit me in.
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
