I've got he HPX all round on the the wrx, very happy with them, good cold stopping abilities and seem to handle some good hard street stops.
Will be doing to the a1rm on the skyline when its ready to come back out to play
  • Replies 14.2k
front page of the australian.
THE navy's $6 billion Collins-class submarines face serious operational restrictions after being hit by a run of crippling mechanical problems and troubling maintenance issues.
ok so we need some help guys, whats the biggest turbo hks make? anychance there is a RB30,000 kit?
according to the australian our swedish engine is no good :) musta been the boost controller i installed and upped it to 400psi
Edited by Inline 6
try ebay..or racespec..same thing :)
Well had my first run in with SAPOL in the GTR today. Got pulled up on Fletcher Rd by one of these but a little older. Had surf boards and all on the roof racks and even a "UNIT' sticker. Pulled me up because I wasn't the registered owner of the car (but I had changed it yesterday). Let me go with "Just be careful for me mate"
Did it have police insignia and sirens? With surfboards? Dude show u his ID ?
-D
Yeah Dohmar. He even showed me the screen saying it was still registered in the old owners name. I didn't even believe it. I even said to him "man thats sneaky as" he just laughed and replied with a "We gotta keep you young ones on your toes"
YAY ABE IS HAPPY :ermm::blink:
Got my car back today, runs like a dream. It is now making 265rwkw @ 15psi and 2 degrees extra timing. Full boost is seen at about 3.5k-4k, it is a little laggy for my taste but means i cant exactly mess around as much, so fuel economy should also be good too. However, once boost kicks in....you know it :( .
Whats it got;
Nismo 740cc Injectors
Garrett GT3076R (3037S) with 3" Front/Dump and 3" Magnaflow Hi Flow Cat.
Haltech E11V2
Turbotech Boost T
NGK Iriway7 Sparkplugs
Superspark Coil Packs
Also had the timing belt and accessory belts changed as well as the belt tensioner and spring, oil, oil & fuel filter changed, water pump and seal changed, also the front crank oil seals too.
Dyno Sheet
Edited by Aberax
Whats it got;
Haltech E11V2
Turbotech Boost T
Dyno Sheet
Excellent result... those Haltechs are a serious piece of kit
Makes me wish I had my turbos already, I have got some siemens-deka racing injectors on their way but only 575... I won't ever be needing bigger while the car has N1's...
(and the injectors cost $360 aussie from the US, and that includes shipping. i love the near-parity... great time to buy from the US..)
soon as they arrive, I'm gonna buy some isc camgears and have my mechanic tune it all
-D
nice power curve u got there mate
did u get a print out of the air/fuel ratios??????
I am a bit of a noob when reading Dyno Graphs...but i believe it is the dotted line on the graph i posted. I think it starts off at about 13:1 and then goes to about 11:1 towards 7000rpm.
Edited by Aberax
that looks like some kinda ratio AFR:P, so what is P ??!?!? becuase its all over the place as far as a straight /normal AFR map goes...
I don't think the AFR's are supposed to be too linear.
Anyway, for comparison, here are the Dyno sheets from earlier in the year when the car was more "stockish"
Power/AFR
Power/Boost
And maybe later i may post pictures of my engine bay.
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
