ruby do u want dales seat? if not ill take it!
Yeah I do mate ... just a matter of meeting up with him. Gotta get the Stagea to the EHP show after work today, then a handful of appointments over the weekend to work around.
Why? You going to hold my welder to ransom? ;)
  • Replies 14.2k
The difference is going from the standard RB20/25 over the top intake manifold to a front facing manifold then there would be gains to be had, but Luke's manifold is a GTR manifold and there are plenty for GTR's making up to insane amounts of power still using the factory GTR manifold.
The Greddy and hypertune manifolds will give you slight increases in the top end when you are making massive amounts of power but you will be getting this gain at the cost of low down and midrange power, and like SLED said your only talking 20-30HP gains on a 700HP engine but your are losing like 80HP below 5000rpm
x2 :/
yeah i mean Turbotech :/
my current boost curve drops off a fair bit, from 10psi down to around 7 by redline. holding the boost higher through the revs with the new boost tee will obviously affect my tune wont it?
might do Damo - you had it all retuned very recently didnt you? give tuner a buzz for sure
The main reason I'm keeping the stock plenum is cause of it's legal and I'm short of the cash, also read they can hold over 400. Once I build the 30 with the race head i may go something more crazy
well i found out my exhaust manifold leak from the track day was due to only 1 bolt holding the turbo on!!!
coz the manifold doesnt have the locking tabs on it for the bolts they must have come loose.. LOL
but coz its a f**king ca its hard to get to the bolts!! ahhhh cut nuckles!
yeah i mean Turbotech :blush:
mines starting to spike out to 1.2 bar, but im thinking that has a lot to do with my hks inlet snorkel.
hey guys, first of all, farkinn brilliant weather eh?
perfect for my durable ranger skin!
need a favour, can any one pick up amy rb20 from ingle farm, and drop it off in ingle farm tomorrow arvo sometime?
will pay petty $$
hey guys, anyone who can help me with getting an apprenticeship as an electrician or at least point me in the right direction will be a big help
PM me your age, details and experience (if any) - can't promise anything but can at least give you some advice, Peer training is prob the way to go.
She looks nice any which way, but yes, preferably without clothes
She'd look better in my bedsheets!
:happy:
... actually, she'd look better with another woman on her ... preferrably Charlize Theron. :drool:
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
