Thats something that would shit me too
Theyre >sitting< in their offices and doing non manual labour - they got their aircons tho, probably reverse cycle, chewing up 3kw of power per hour
Factory workers, busting their arses in hot weather and they get given a spray bottle? Nigga please
Time for a riot (or to get the union to do their damn job for a change)
-D
+1
our bosses sit in an a/c office all shift and come out for maybe 5 minutes a night to give everyone the eagle eye and go back to there 20 degree room :P we move tons of freight hourly by hand rain hail or shine. i get paid decent to do it so i dont care heaps but to make us work in 40+ heat for the same wage and same hours is bit of a joke
  • Replies 14.2k
-D
shit there after us white collar nerds....panick
how do i change a .odt file into a .doc file?
is it just changing say xfile.odt and ending it in .doc? so it becomes xfile.doc? got no fkn idea, stupid computer doesnt even have word. has some "open office" thing.
cheers for that Damo and Krishy. Emailed a resume off and got an email back saying yes, your cover letter sounds like you are a very good candidate, but your resume is in a format we are unable to open.
More than likely thats happened to the 10+ jobs i have applied for, and heard nothing back..ergh.
Actually gets a bit chilly sitting around in datacenters/server rooms, now if only IBM graced us with variable fan controls.
You could always just sit infront of some cisco routers or a NAS cluster :P
I love server room aircon. Nothing quite like 24'c constant when you're in a collared shirt
-D
When I worked at the winery it could get a touch warm, but they have evaporative aircon in 90% of the work area, some even have refridgerative. Only 1 hall doesnt have anything but the building is coming up on a 100 years old so its pretty cool anyway plus there is no heavy machinery in it.
At my current job which is still manual handling the whole place except the dock is climate controlled to (what feels like) low 20's.
I feel for ya though guys :P
Anyone know the policy about a factory closure due to warm weather? Like, a law.. that says you have to close it once it gets to a certain temp like back at school?
every employer will have a different thing
our heat policy is basically this
- have plenty of breaks
- drink as much as you can
- take measures to get out of the heat as much as possible
so basically i leave the truck running while aloft, we've got the windows up and the a/c on. carry 10 litres of ice water on board, and most of that gets drunk during the day, and once our run is complete we go back into the depot and sit in the lunchroom till knock off
-D
Some peeps may have heard of The Tunnels just up the road from me in Panorama........they're used to store wine now and maintain a constant cool temperature.
Be nice to park myself in there for the next week or so with a big screen TV and access to the various Grange bottles in there :P
Some History: The Tunnels
The tunnels were built in 1880. The first ever tunnels built in South Australia, they opened up the line between Adelaide and Melbourne. The tunnels were decommissioned in 1920 when a new tunnel was built to eliminate the problem of sharp bends, single line and an inadequate viaduct.
The Tunnels were used during the war to store government documents and artworks.
The tunnels were transformed in 2003 and became The Tunnels Wine Storage.
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
