  • Replies 14.2k
s15's dont do much for me anymore , unless its Ben's s15 or the team orange one
Fixed. Shame seeing such a awesome car get banged up often. But thats drift. Was so awesome to help build that car every night after work.
Yeh, which Ben built from the ground up with the help of my bro, and other mates. I was there most of the time lending a hand where possible.
Miss those days
Correct; Matt made some billet parts for it as well
http://www.doylecrash.com.au/jesus_project2.html
http://www.nissansilvia.com/forums/index.p...282351&st=0
need fuel pump for 31,
i dont think ill do the fuel cell set up right away, so an internal one for now will be fine.....
obviously whatever i get will have to be re-wired eh?
not a great deal of "re-wiring" as such
either get an 040 or a GTR pump. Its straightforward once u get the cradle out
I can't see the point in fitting GTR pumps these days. the youngest of them are 7 years old and the oldest is 20 years old.
And when you can get a 040 for $180 it doesn't make sense to me.
aye for the price the 040 is decent, but if you're chasing high numbers a nismo is quite a nice upgrade
-D
What times are you clocking currently?
10.485 down 1/8 mile.......that was my second ever run, hoping to get a lot more runs 2moro night....
cool. can you start with my garage? its needed a sweep out for a while now.
:action-smiley-069:
nah i gotta play with some big boys toys :happy:
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
