  • Replies 14.2k
WHAT??
if you find it is, let me know asap, i know where this mothr-fkr lives!
prick told me it was all sweet!
Kinda hard to tell if it is or not, but it doesn't look good. It's that or the harmonic balancer is bent or some shit. Either way it's not exactly 'all sweet' :P
It drives normal though, took it for a quick drive up the street before :D just makes a fkoff bad sound from the HB having it's way with the timing belt cover.
take the cover off, then skid.
then snap belts, then be up for more money to fix shit :D
Nah the cover actually looked loose at the bottom, like it was sitting closer to the HB. Probably why it's making such a fking racket.
There will be skids :P just wanna make sure I'm not gonna break it while doing them
my new ride
Miss Abby
Looks good Cara.
I think I've unofficially named my GTR 'F_ckin' Car' cause that's how I usually refer to it. Your names of Betsy & Miss Abby are much nicer.
Looks good Cara.
lol its Miss Betsy hahaha
and dont worry i think the 34 has been called every name underneath the sun lol
thank f**k i do teleconferrencing from my office
^^ the only teleconferencing you do is with 1800 numbers ya knob :)
Lol Krishy's phone time is more like:
"Hello may i speak to the business owner? Are you happy with your phone service?"
:D
well not the calls i have been answering all morning Damo....got damn i hate dumb users......specially when they feel its ok to do morning calls at 8am......what is this Krishy's hotline :@
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
