  • Replies 14.2k
if you're not labouring it, use 5th
ive gone back to that in my fourby, gets me an extra 100km out of a tank easy just doing that
+1. I'm almost always in 5th at 60 km/h and and when it's flat I often go through 50 Km/h zones in 5th too. :)
if i try to use 5th at 60kmh, the car nearly stalls....
1st = 0-96km/h
2nd = 133km/h
3rd = 175km/h
4th = 205km/h
5th = 2xxkm/h
Factors Affecting Fuel Economy
Fuel economy is affected by a vehicle's size, weight, aerodynamics, fuel delivery system, engine type and transmission type. These values remain constant for a specific vehicle.
There also are many variable factors. As mentioned, the heating value of the petrol is one. In addition, fuel economy is affected by weather conditions, air conditioner use, road conditions, the route driven, driving speed and driving style. And it is affected by the mechanical condition of the car - engine tune, wheel alignment and tyre pressure. Some of these non-petrol factors have the potential to cause substantial changes in fuel economy. The table below shows a list of average and maximum effects published by the United States Environmental Protection Agency (EPA).
Click for image
Winter-related factors can combine to lower fuel economy 20% compared to the summer. Rain or snow on the road offers more resistance to the tires. It may also require the driver to slow for safety to a less fuel-efficient speed. In cold weather, a richer air-fuel mixture is required to start and warmup the engine. And much of the warmup is done at idle because of the need to defog or defrost the windows. Also, in many vehicles, the air conditioner is operated to assist defogging. More energy is required to overcome the resistance created by the higher viscosities of cold lubricants - engine oil, transmission fluid, and differential lubricant.
Short trips are worse for fuel economy than long trips because a cold engine uses more fuel than a warm engine and because of the energy required to overcome the resistance of cold lubricants. Traffic jams and bumper-to-bumper driving also extract a heavy toll on fuel economy.
http://www.chevron.com/
Conclusion
We don’t think any of the points made in this article are groundbreaking. Bluntly, they are not. But if you select the car carefully on the basis of the real needs it must satisfy, keep it well maintained and drive it well, you will be getting the best fuel economy possible in your driving circumstances.
No shit! :)
that article doesn't mention the use of 5th gear at 60-65 km/h....
uhm... fuel consumption isnt directly effected by revs, load has more of effect.
Revs has something to do it for sure, the lease cars i used to get with the trip meters in them that show instant fuel usage backs that up, driving down heaslip road doing 90 it'd be showing me using more fuel in 4th at higher revs then 5th in lower revs...But Steve has also hit the nail on the head with that post he's put up sums it all up really
Was walking down hindley around 3am this morning. I see the undercovers 4wd, cops jump out to help with this fight. One guy who was involved in the fight runs off towards me and 5 cops chase after him down hindley. My mate kicks the guy in the leg, slows him down abit, cops still chasing him, tackle him from behind and the guy goes straight to the ground. Everyone cheers.
Was fun to watch this guy get decked.
Thats my exciting night :(
LAWL i saw that i was crossing the road all the cops ran out the 4wd n ran past me n ma mate haha i thought someone cleaned the guy up be4 the cops did becoz everyone was clapping n cheering hahaha oh god it was funny!!
epic fail for the guy fleeing the scene :)
lol, not a bad score at all. considering you can buy the same seat in the same condish for about 10 times that.
shame that rail i pulled off it is a passenger rail. might just flog it.
+1, my old man told me that 5th should be reserved for anything over 80, and that goes for the majority of cars
you need a certain amount of revs to cycle the oil system to the required pressure, I would never drive 60kph in 5th unless it was downhill (in which case the drivetrain is not under load)... the gear ratios in a GTR are quite nice imho, I wouldnt want to change the ratios for a daily driven car... on my weekend hills run, i very rarely used 5th gear and the fastest we went was 115kph, so I kept it in 4th for most of the way, and the entire 2 hour run took just a tad over a quarter tank... most of the time the car was in 3rd doing 4000rpm around corners, so I wasn't being gentle, and yet it took much less fuel than I estimated
-D
woo got my seat from JMS, little bit haggered but nothing i cant fix up. not bad for $49 :)
if you change your mind and your wanting to off load it ill give you 100bux for it how it is.
im keen to use it in a ps3, steering wheel setup lol
if not ill just keen using the ebay jobby but fixed back in your living room sucks wang
yeah RB20 isn't too fond of doing 50k in 5th, will just handle 60 aslong as there isnt any hills or sudden accelleration required, but 4th fits the bill fine, even 80 in 4th sits fine. Will be interestering to compare the new 25/25 engine/gearbox combo...
lol. this is where i up the bid to $150... could use a passenger seat. :)
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
