  • Replies 14.2k
This happened twice tonight, I'm going 55 in a 60 zone (to conserve fuel) and in both cases, a cop in front of me slows down to around 40, even when he has other cars behind him. Once he realised that my car is completely stock they turn off into some random side street, probably pissed off that he won't meet his quota tonight :wub:
i think you will find the police drive slow everywhere, unless there is a reason to be somewhere.
Thing is though, he was probably going 55-60 as well before he spotted me, and as soon as I slowed down to around 45, he slowed to around 40.
Meh, you want practical... buy a Hyundai Excel lol
cmon theres a difference between practical and pussy
like people running low low suspensions that cant even handle twisties because "oh it makes my wheels rub on the guards"
maybe think of running your car half a bees dick higher and it'll be able to >do what the car was designed to do<
autosalon spec suspension = fail. twisties + cruise/daily spec suspension = win. especially in south australia, where roads are designed by orks.
-D
-1
Impractical as buggery. Fine on jap roads but here you'll be rubbing more than oprah's thighs in a marathon
looks like turd to boot.
-D
Edit: +1 for Dohmars' second post.
discovered 3 things in the last 48hrs
1. Vics are very courteous drivers on their highways / freeways (ie if you're coming off an entry ramp, they change lanes so u can get in)
2. Amber lights dont stay amber long at all (barely a second)..........so no more "plenty of green in that" calls over there
3. i need an intercooler on the patrol BADLY
win, wonder if its static or bagged. extra points of its static dropped.
as for the practicality thing... meh, im running pretty low with a reasonably aggressive (*waits for jarrad*) wheel and tyre combo, and the only place ive ever had trouble with rubbing on the guards (im not counting liners, theyre retarded) has been turn 1 at mallala, over 100km/h and tipping into a long right without brakes puts a lot of weight into the front left corner, solution, bought it into the sheds, hammered the tabs on the guards down, went back out and it wasnt as much of a problem. skinnier tyre would fix it completely.
... could use some rca's though, then itd be spot on.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
