  • Replies 14.2k
category 1 (< 15km/h) = 1 point
category 2 (15 - 29 km/h) = 3 points*
category 3 (30 - 44 km/h) = 4 points
category 4 (> 45km/h) = 6 points (and a $564 fine + $30 levy, lol)
*same as failure to stop at a yellow or red light.
ive now been fined for everything but a cat 3. not a great record.
fixed
*same as failure to stop at a red light.
45+ you also receive a summons to appear for "speed dangerous to the public".
so... in 28 days ill be losing my licence. bit of a bummer. but they couldve raped me pretty hard.
copping a 6 month suspension and a $600 fine. but considering what they couldve done me for, that isnt too bad.
dw mate send it this way ill look after it real good :banana: we can has hillzy every weekend
you possibly have very bad phone lines or live like 7km's from your exchange, the further you are from the dslam the more 'overhead' you loose (my terms and thinking may not be 100% correct but very close :)
you dont want to see mine :banana:
EDIT
log on to router, and there should be a status page there that tells you all you need to know
it also depends on the line profile selected on the internode end - you can check this/change this using your account login.
also if you log into your modem, ensure that it is set to use G.dmt modulation rather than g-lite or ansi
Another thing to do is to disconnect every phone device from the phone extensions in your house (including line filters) and just run the adsl router by itself - if you notice that there is a speed increase after doing so then it points towards attenuation on the line due to either a faulty line filter or bad cabling.
-D
-D
no idea on were to go.. hehe..
If it is a Billion modem, open IE/Firefox/Chrome. In the address bar type 192.168.1.254, you will be asked to log in, Username: admin, Password: admin. You shall now see the status page.
All other modems will be similar, only differences being the IP address and maybe the log in details.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
