thats weird craig i put my phone number in and says i can get it and gives me a link to a page of possible speeds >>Here<<
im with bigpuddle cable extreme for the price i pay for 12gb TPG will give 100gb and shape you to 1000kb/1000kb which is pretty good
used to be about $360 Adrian club members get 10% discount :) edit (that was full dump pipe to cat)
  • Replies 14.2k
Tel$tra is a scumbag organisation, change over, you won't regret it
used to be about $360 Adrian club members get 10% discount ;) edit (that was full dump pipe to cat)
when ever ive tried to obtain a discount in the past i get looked at like "wtf are you showing me that for" :)
2 words Luke pair gain
and i would rather sacrifice download limit for raw speed the most i would get out here is about 3.5mbit on cable i get 20mbit
2 words Steve, Shit Heads :)
or
Bad service
or
f**king liars
or
You see I have a high opinion of them
screw optus too
useless kents
apparently i live at campbelfield qld :)
does that even exist??
i have rang and told them atleast 3 times, and still, the billing address is qld.
my bills get sent right to my online bank, so if it wasnt for that, id prob never have seen any bills..
steve, i have one of those new numbers 722 66... maybe that has somethin to do with it?
screw optus too
useless kents
apparently i live at campbelfield qld ;)
Isn't that a VOIP number :)
Im on a non-ADSL enabled pairgain/RIM. Joy.
Its now 2010, ADSL1 has been widely availible for what 9 years now? I still cant get it. My exchange has ADSL2+ aswell but I cant get that either... And to make it even sweeter, my street has cable but its not commissioned :)
hey matty,
sent you the moneys for the afm..
should clear tomorrow!
cheers mang
do u know when u will get them?
no idea when mate, gotta wait for the money to clear into this guy's account, so probably at a guess the end of the week.
ok man,
just hit me up when u got it..
i will be away till next thurs as of sat..
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
