shane is that on the stock hks wastegate taht comes with the manifold??
coz im thinking if i can get the gate running 14psi then i can set my eboost to run 14, 16, 19 psi?
should be sweet.. i guess i can try and if not upgrade..
  • Replies 14.2k
sorry Shane, just seen ya post.. he's 4 months, just a tad big for his age lol
he was in a shitty mood before, but for some reason loves drift dvd's and jap sliding on youporn i mean tube
i whacked on a street commo dvd a second ago (first one i could find) and he screamed the house down
so i whacked on drift central '' Luke fink go time'' and now hes laughin at the T.V, def my boy :)
Yes he is, nothing wrong with that though :banana:
Enjoy them whilst they're not moving though cause once they start moving their into EVERYTHING!! Haha such fun though :banana:
Yer mate, i can't run anymore boost then that atm cause im already running lean!
nasty
my old man has got that car; bought mr.pickles (auctions) personal car only 4000kms on the clock
pristine condition, had it over a yr now. TT powah!
nice car thats for sure, his retirement dream :)
yeah I love it.....has towed things and taken me places that my Prado couldn't handle.
Everything from towing a very large caravan to driving on the moon!
Check it out:
Lunar Surface
Small Martian in the background
Flat as!
One of the moon's craters.
Zero Gravity.
man, youd wanna have a good car to be out there, i find it bad enough driving my company car up
the freeway on a hot day :)
Not wrong Craig.
The locals were telling us that they don't bother recording temperatures that exceed 50 deg but temps in the mid 50's are quite common.....whew, I'm thirsty just thinking about it again!
All Skylines would die up there unfortunately.....and some 4WD's too, lol.
Nothing grows with that heat, not even weeds.
u might be able to change the springs inside the wastegate so u can run more boost, when i bought my turbosmart gate it came with 4 springs
running your gt3076 with the .7 compressor housing on your low mount manifold might have clearance problems with your engine mount
when i mounted my gt35 on my 6boost low mount manifold i had to have the engine mount machined down a bit to make it clear
whos gonna be at drift prac next saturday? as in, sliding..... not sitting on the stand with a hard on wishing
your car was finished.
I might actually go and enter. It's been awhile since I entered or even gone to watch.
Those manifolds were sold with in the HKS GT3037 kits which is the HKS version of a the GT3076 so he shouldn't have any trouble. you can see on the front 3 runners they curve up before the collector which allows for large compressor housing to clear.
EDIT!!
LOL that's not what you were saying though, the kits were bolt on items though so there shouldn't have to be any mount modification needed, from what i understand they actually move the turbo forward slightly from the factory position.
Edited by D_Stirls
Your apology is accepted and I appreciate that it was done publicly rather than by PM.
IMHO, it takes a real man to come out in public and apologize, so thanks.......water under the bridge now. :P
I'm sorry you're bold Pete :P Apology accepted? :teehee:
I know that of lot of people on here have arguments with their wives and girlfriends over the amount of time and $ spent on 'that bloody car'.
Valentines Day is approaching so I thought that I'd put forward this T-shirt as a gift suggestion:
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
