  • Replies 14.2k
see, its either channel 9's idea of "marketing" a show they stole off SBS and tryin to make it popular on their network, or the way of killing a show
i think its a poor attempt at advertising, which will end in the latter
just so you know matty, channel 9 now have the rights to top gear.
i know that craig
by "stole" i meant "bought with eddie's squillions only to put it in a shit timeslot and hope it fades away"
On a slightly different note
Lie Detector Test
Shame the court appearances don't happen before the election.......may sway a few of those old pensioners out there that think butter wouldn't melt in this bum's mouth.
anyone know if nisstune remaps can be REtuned?
yes, thats the whole point of putting nistune on there. a remap can be achieved by flashing over the eeprom of any ECU however the nistune actually lets you adjust each variable in real time..
troy, looks like shes giving head... which i suppose is why she has her name tattooed upside down (incase the one night stand is too drug munted to remember the name of the hussy going down on his unit... epic tattoo fail that
-D
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
