Who the Fu*k would do this.
Someone has walked into my front yard, gone to the garden hose, cut off the end with the connection and wheeled off like 10m of garden hose and cut it again.
What the..
I'm Sorry, i didn't know it was your place...would you like it back? :D
Indeed, that is very much WTF
  • Replies 14.2k
What the..
Yeah about that... sorry...
What the..
GOLD .. you just got to love it :D thats what you need
yeah, snapper are awesome fish, good fun to catch and excellent eating... chuck them in a charcoal fired weber, they come out pretty darn nice.... max limit is 1 snapper per person but you can get 6 ruggers each legally too (ruggers are juvies)
-D
damn thats a huge fish
Speaking of which Dohmar, a bloke came into the Holdfast Bay marina last week, as i was working on a boat, and whipped out 2 huge ones..and a few of those juveniles.. within an hour of getting out there..
something around 18 pounds or so.. Just out the front of the marina..around a k or two..probably Glenelg Tyre Reef..
i cant fuuking believe how much i look like this dude, we even went to school together!
vv me vv
http://photos-a.ak.fbcdn.net/photos-ak-sf2...260627_3948.jpg
vv lookalike guy vv
http://www.facebook.com/photo.php?pid=1220...100000071388861
maybe ur mums both had the same milkman back in the day :P
-D
vv me vv
vv lookalike guy vv
yeah its pretty good out there this month... this weekend in particular is looking like a nice clear, windless weekend...our original charter had an issue with his primary 400hp diesel and has to fly another $20k engine out from belgium, which puts him out of the charter game for a month at least, thankfully he gave us the number of a mate of his from another township nearby and got the booking made this morning.... best thing about charters, you might pay anywhere from $150-$250 for a day out on the ocean, but you'll leave with about that much in fish... 9 kilo snapper is worth around $180 at $20 a kilo, so you catch one snapper, 6 ruggers and 20 king george whiting, you've easily made your money back
-D
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
