Who the Fu*k would do this.
Someone has walked into my front yard, gone to the garden hose, cut off the end with the connection and wheeled off like 10m of garden hose and cut it again.
What the..
I'm Sorry, i didn't know it was your place...would you like it back? :D
Indeed, that is very much WTF
  • Replies 14.2k
What the..
Yeah about that... sorry...
What the..
GOLD .. you just got to love it :D thats what you need
yeah, snapper are awesome fish, good fun to catch and excellent eating... chuck them in a charcoal fired weber, they come out pretty darn nice.... max limit is 1 snapper per person but you can get 6 ruggers each legally too (ruggers are juvies)
-D
damn thats a huge fish
Speaking of which Dohmar, a bloke came into the Holdfast Bay marina last week, as i was working on a boat, and whipped out 2 huge ones..and a few of those juveniles.. within an hour of getting out there..
something around 18 pounds or so.. Just out the front of the marina..around a k or two..probably Glenelg Tyre Reef..
i cant fuuking believe how much i look like this dude, we even went to school together!
vv me vv
http://photos-a.ak.fbcdn.net/photos-ak-sf2...260627_3948.jpg
vv lookalike guy vv
http://www.facebook.com/photo.php?pid=1220...100000071388861
maybe ur mums both had the same milkman back in the day :P
-D
vv me vv
vv lookalike guy vv
yeah its pretty good out there this month... this weekend in particular is looking like a nice clear, windless weekend...our original charter had an issue with his primary 400hp diesel and has to fly another $20k engine out from belgium, which puts him out of the charter game for a month at least, thankfully he gave us the number of a mate of his from another township nearby and got the booking made this morning.... best thing about charters, you might pay anywhere from $150-$250 for a day out on the ocean, but you'll leave with about that much in fish... 9 kilo snapper is worth around $180 at $20 a kilo, so you catch one snapper, 6 ruggers and 20 king george whiting, you've easily made your money back
-D
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
