ok, maybe you should get on f these in your 33 4 door. just incase you forget to put oil in your engine again and need to be rescued...
Didnt you know craig....steve is going for a build that doesn't require oil to run....
  • Replies 14.2k
can any of you more so computer literate people get this link to work?
http://www.dingdang168.com/UPLOAD/PCN-DON001.rar
i need it to get my bluetooth dongle working, which was MENT to come with a driver...
bloody chinease
bezender, thanyou for your concern from my alarm thread
I did find what I was looking for
good to hear andz :) it got a bit outta hand didnt it
bloody chinease
try the googleizer and find another source for downloading it
on the topic of treadmills
you will like this Craig
rofl, thats classic. love the look on that guys face.
hey, are u the same craig that i sold a hard back seat, and came round to my place to swap an LCA on my 32?
bloody chinease
Give this a go - If it doesn't work, post up the details of your dongle and ill try and help.
that site failed Abe, pretty sure i aint payin for it! :)
If that is your Dongle, did it come with the small driver disc?
Bluesoliel is free, try it from here, if the previous link i gave failed.
yeah what i linked you to was it, it was MEANT to come with driver CD, but didnt.
and when i asked the seller where it is, the retard gave me that fail link!! heaps good....
ill give that one a shot Abe.
well i just had the worst most blood curdling experience siting down stairs waiting for the folks to get home when i hear the car pull up and wait for a ding dong
when i hear a child scream i thought nothing of it because we have kids over the back who throw tanties from time to time when the amplitude of the screaming doubled and i went to the back door to only realise it was my daughter screaming
when i got to the front door she was running to it screaming daddy daddy holding her fingers i rushed her in to see no blood phew no blood so i took her in praying for little fingies and running the the paracetamol you can never be to care full with kids and electric windows, i also think nan and pop panicked when they heard the screaming and rather than open the sun roof they closed it further, but the toyota camry has a stupid switch mechanism
all is well and daughter is in bed with ice pack in tea towel on fingers
Started stripping the engine down tonight from the RS250 race bike. It appears I've wasted the engine good and proper due to a failed oil pump. The 2 stroke v-twin uses an oil pump operated on throttle control ... somehow the pump failed and 9,000rpm down pit straight was enough to punch a hole in the block. :) Time to go pre-mix instead of relying on a known fail part.
Guess I'm missing the first couple of rounds of racing this year, as I've already gone thru my first engine during practice! :)
Anyone got an Aprilia RS250 or Suzuki RGV250 engine lying around? :P
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
