well since everyone else is saying they know the guy i thought i would say something too
i shared a shed with that blue sil80 at aq drift day last year i think and talked to the owner which i guess might have been you?
wow i feel so popular :blink:
i remember you man... it was great chatting that day.. hopefully we can say hi at another drift prac soon :cool:
- craig
  • Replies 14.2k
anyone know if 34 GTR castor arms fit GTST ?
they look like the same dimensions but GTR ones have a kink in them for more/less castor and i cant seem to get the front bit to bolt in
Than I would have to say no at a guess
they look identical to stock ones , but who knows with my car.
ill try get some stock GTST one's to compare
nismo castor rods have the same part no. for S14/15, R33/34 RWD, so I'd be guessing that GTR rods are different Mitch
I have a set of stock ones with rooted bushes if you need to compare
Be a cool Step Daddy and build the kid a SLED!!
You know what? ... I typed that, read if afterwards and wondered how long it would take you. :yes:
I'm sure Cam would like something that can go around corners tho Pete :D
Got a 100cc go kart coming for the little lad. Its a project for the two of us to rip it down and rebuild it so he can get into some kart racing ... and I'll get the odd ride in it. :thumbsup:
Here is a wasted engine for the Wasteland ...
Pulled the engine apart from the race bike today. It shows one cylinder gone off like a grenade. :yes:
Clothes off, engine out ...
What was left of the conrod punched a hole in the engine casing ...
Crank is also rooted ...
The barrel was destroyed ...
And this is the piston !!!
:thumbsup:
    • ..and forum.r31skylineclub has been down all week....anyone know why?
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
