  • Replies 14.2k
Well they say bad things come in 3's, my R32 has now fulfilled its quota.
Tuesday: Vandalised
Thursday: Hit Rabbit, broke front bumper and damaged RH front guard
15 Minutes ago: Broken Windscreen
Tuesday: Vandalised
Sign up to the RAA Plus for $115 and call them a week later saying your windshield is broken
You'll get the windscreen for free (part of their policy, you get one per year) not to mention the 12 months worth of cover (including accomodation and towing)
-D
Edit looks like the free windscreen per year is only for the insurance arm - funny, I could have sworn they were a part of raa plus - looks like shannons offer the same thing without excess
Ive got full comp insurance with Shannons, I think I get a free windscreen as part of it.... Anyway cheers for that.
Thanks Steve :cheers:
Edit: Go Shannons! The car is booked in 11am tomorrow for a brand new one.
U may need to pay for the rubber molding around the window tho.
They dont mention that, only the windscreen is free.
That should be covered by the policy. Its not like a new seal is optional when fitting a new windshield.
-D
-D
I would call shannons and ask, just make sure cause sometimes it doesnt.
who wants a daily
>>R31 GTS<<
i wouldnt daily that steve, thats one for the weekends. one of the manual ones too *drools*
i want a GTS1 for a daily / weekender (for when i dont want to drive the poo-trol around)
f**kN WOOOOOOOHHHOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
just got a call from the agent whom we put an offer on a house to yesterday, they accepted and he comin round tomoz with the contract :cheers:
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
