went to buy a nardi that ive had my eye on for a little while from jis today, last time i was there had an s14 srs suitable boss kit there aswell, no more boss kit, sold the other day, means no wheel. :P
  • Replies 14.2k
R33GTR Brembos onto a R33GTST front, do i need any different hose connections from the GTST to the Brembos? As i am thinking of getting these braided kines, and want to know if they will still go from the standard lines and then go to the Brembo's.
hey dion thanks for tonight being driver and all
sorry for having 2 crows players by the throte tonight at the toilets but you saw them grabbing me it had to be done but anywqay how funny was it really lol and as if they sent 4 security gards to sort it out lol far tiddley atm and this just took5 min to write
The club should have dealt with them before you had to - I saw you telling security earlier in the night. Just because they are footballers, doesnt mean they can do that sort of thing.
they had you by the throat :S shuda ripped there balls off
no babe i had them by the throat, i grabbed them and slamed the first one up against the wall by his throat and told him if he touches me again ill knocked him out the the other one was coming out of the toilet and i then grabbed him and told him the same, you see they both grabbed me 4 times during the night and they wernt little grabs either and all of the times were in front of security, i warned security" if they did it again i will knock them out so you better grab them first" well they didnt so i delt with it lol, then they sent 4 security gards running lol when i had them lol i mean really im 5"4 was in a short ish dress and 6 inch heels lol
sounds like a fun night, any idea who they were?
-D
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
