  • Replies 14.2k
Are you ok Cara? Any updates on your friend?
Sorry to hear about the cars involved but your health and your friend's health are way more important. I hope everything works out ok.
my friend had surgery on his back today not sure what for, and i dont know whats happening but im going to the hospital tomorow to see him
As i have just admitted to being a cheap-ass in The Spotted Thread I am going to post an interesting link, Here, to rebuilding brake calipers - As i am replacing my Pads, Rotors, and going Braided Lines for the Track Day, I may as well renew the calipers too.
I did the caliper seals, makes a load of difference.... 20 yr old calipers vs as new... no contest
-D
I'll stop whoring it up in the spotted thread, that DIY looks good. extremes are good if your good to them lol
Yeah, ATM i am going easy on it as i am "bedding in" the clutch and new flywheel.
Only thing I dont like about mine is it doesnt fully disengage the gearbox when it gets alot of heat into it. As for pedal feel? A few members here have driven my car and they have all said it has a great pedal...
EDIT: If you want to hear something really interesting, give Jim Berry a call and ask him about his opinion of Extreme Clutches...
Definitely not a good thing.
should i set the day aside for the call or?..
well back from Canberra/Sydney had an awesome time
only saw about 5 skylines and about 3 coppers so that's a great ratio
sorry to hear of your accident Cara, hope your mate recovers well
why dont you get the R Vu your looking for a 32
ive had my current Extreme in for about 14 months i think
i know its not a skyline people, but your a pretty switched on bunch of peepz,
does anyone know the stuf pattern size for a rx7 series 4 and what other car rims will fit on here.
I have searched google no results, asked mates they all look at me like im planning on giving the thing a good hiding it deserves. p.s sorry bout bad spelling had a few too many. need to get some stockies or decent type rims, and no i wont be doing burnouts on the road, i got no licence to do that anyway.
He won't get one... hes so worried about it not being the perfect one that he'll never actually find a GT-R aha
perfection only goes so far as your wallet allows
note the aus delivered r32 gtr and the one with less than 10,000km milage being advertised on carsales, but each one was over $40k ($65k for the aus delivered one)
-D
If he wants perfect, he will need to increase his budget substantially...
EDIT: Beaten by Dohmar
i think 13k is worth the risk that it might be a genuine sale fly to Perth have a look @ it buy it and put it on the train for home then spend $1000 change all fluids and get leak down and compression tests done so you know what your dealing with
if it has poor compression drive it easy if its all good smile all the way to the track
EDIT
if i had the abilities to acquire 13k i would snap it up today
I totally agree with both dohmar and heslo, hence why I spent the amount of money on my GT-R that I did. I can see that GT-R being a nugget and chewing a bearing straight away, personally I'd steer clear.
Edited by Weezy
its not too bad, tho you're right about the engine, you'd probably want to rebuild the engine straight away for peace of mind, or just strip the car down as much as possible and use it as a track mule till it breaks
i wouldn't mind a 2nd gtr which I can nick parts off
-D
Edit - Having had a look at the pictures, the engine bay looks like its in pretty decent nick and the interior looks good too (no tell-tale bubble on the dashboard)
If your budget was $25k, then getting this one for $13k and spending $12k on replacement parts would be a fun thing to do
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
