  • Replies 14.2k
got really tired of hearing the ford vs holden bs there, its the same friggen car with different headlights and tail lights. quit telling me how sh*t 1 is compared to the other. and those utes were slow as f**k, funny how they still manage to loose control all the time though
i was thinking the random talent was better than the promo chicks.
Edited by Inline 6
you obvioulsy no sfa all about the utes then.
I hear you neck becomes slightly more red every time you drive 1 :( im sure they are the coolest out in the stix.
taken from their webpage "The Ute's are production based, and with limited modifications" i was under the impression they just had exhausts and maybe a brake upgrade.
Edited by Inline 6
to be honest i dont think i actually saw any of the promo girls while i was there....strange.
:(:O:O:O sooo in love with this car right now lol
Didnt he have engine dramas on saturday......me thinks not so reliable ride that one lol....
Dan as far as i knew the utes were production utes with very very limited modifications.....hence why they only do 8-10lap races and not like the supercars which does 70+ laps........never been a big fan of the utes.....
they not that bad when they start smashing :(
the minis had quicker lap times though :O they was tuff minis though
what would be entertaining is 1 of those time attack sessions like the malala sessions. kier wilsons 32 and revs rx7 n such but im sure they wouldnt like some non holden/ford stickered car beating there lap times.
Edited by Inline 6
As much as I like 32's I would be morethen happy to pick something newer over something that's older.
If for some reason I make some decent enough money on the rigs I'll be looking at evos and f6's (Ba, Bf)
I like newer car :thumbsup:
32's and 33's might be getting a bit old but still has modern technology behind it....look after it and it will look after you
how hard is it to change the harmonic balancer on a RB25???? *looks at dale*
I would love an f6 or a maloo ute over a skyline other then a 34 or 35 gtr
such nice cars inside and out plus power
Each to their own. I personally wouldn't touch anything domestic and if I had to it'd be a Aurion/380 or Magna
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
