  • Replies 14.2k
yeah 044 is external, the nismo ones i've seen for >600 so they're out. 33 GTR pump will drop straight in but i'm expecting Nissan to give some sort of shit pricing.
What trouble did you have with the 040 Abe? Hardest part of the install looks like positioning it close enough to the bottom of the tank.
Edited by nicr4wks
sscond hand gtr pumps go for $100-$200, modify the cradle a bit, and youre sweet. can buy brand new walbro pumps for about $160 from ats, basically the same to fit as gtr pumps, minimal mods and it goes right in.
Edited by scandyflick
Yep I highly recommend the Walbro 255lph - had one in my S15 and my R34. The 040 I had in the S15 sucked up silt off the bottom of the tank and blocked, then failed.
Pumps with socks (like the stock pump and the Walbro) are better designed for Nissans IMHO.
Also, got camber? I have some camber arms ordered to address the problem, but it looks pretty slammed at the moment :D
haha ill take this stagea anyday!!!! http://www.discountusedcars.com.au/used-ca...ea/3483209.aspx
lol someone didnt get enough sleep! or am i misinformed haha
hahaaha at least its an autech
Anyone know roughly what a 33 GTR fuel pump is worth? Or should I just drop in a 040.
i have an 040 was already modded to the cradle so i just dropped in :D
hahah nice Andrew
i go to AutoPerfection tomorrow to have my splits fitted, any one have questions
alarms, installs, tints, what colour undies to wear :D
shit balls. thats crazy.
are you feeling the blue or the beige? im leaning towards the blue at the moment.
getting them to fit is f**king simple if you have a dremel and hose clamp. i was a bit confused when i did mine, but then i looked at went "ooooooh", 30 minutes later it was in the tank.
+1
i rate the walbros, very simple to install, and they do their job well. there's a lot of mixed opinions around other areas of the forum on these, but we chose it over the bosch for its similarities to the std setup. installed, tested, and proven good performer.
fuel pumps arent hard to install if your not afraid of modifying the cradle, getting a few cuts on your hands from the fiddly bits around accessing the tank, and of course inhaling petrol fumes :D
some like to go that bit further and rewire for better voltage
would look even better with some 25mm spacers ;D
only concern I'd have with the wallbro pump is whether or not it flows more than the stock gtr pump - i know this isnt much of an issue till u go over 300kw but I'm leaning towards the nismo (125% flow rate) rather than a bosch
what splits are u getting steve? type R's ?
-D
the stag has had an 040 for 4 yrs now, no issues.
the rb26 sedan has an intank gtr pump and fitting an external walbro 305lph unit - $160 good price
040's are around 190 but you can get copies for around 100
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
