oh yep loving the QFM A1RM's atm......had lucas pads in there before and they went ok on the track day.....except brake fade on the last hot lap of the day....so not too bad IMHO......i still use the lucas pads for on the street.....i will take the qfm's out once the track day is finished and throw my lucas back in for street :cool:
lol why? the QFM's are cheap enough
  • Replies 14.2k
i can tell you what side the hoses come from shane, its right hand side for both
as for bolt spacings, havent got one on hand for that though, would be R31 bolt spacing if it was
Is that right hand side standing at front of car or right hand side of radiator?
So they bolt into R31 as well??
I need bigger radiator, now with the FMIC installed the water temps have gone from under the 1/4 mark on the gauge to over half way...
i want to use up the lucas pads as they still have a lot of meat left on it Damo......
a1rm's are also harsher on the rotors than the lucas pads would be.
not really a fair fight imho
Protest over 'family' flyers
yeah that really sucks - thumbs down on this
although im not surprised that family first supporters are so gullible they didn't read the 'how to vote' forms a little more...
-D
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
    • We want to see pictures of the carnage!
    • The picture of the underside of that PCB shows either old flux that wasn't cleaned properly or some other contaminant (I.E Water). I would flush it with ISO and try again.
    • @silviaz Are you skim coating the entire panel (covering the entire panel with filler) before your hitting it with the long block? Or are you selectively applying filler to the repair, trying to fill the low points?  Please don't do that.  Almost certainly. Are you checking the panel for flatness as you go? Or is it more a case of, sand til all the guide coat is gone then check?
