  • Replies 14.2k
I need new Tie Rod Ends for my R33, and i need them quick, as my car is booked in for the 10th for new tyres and install of the new Tie Rod Ends, before the Track Day. What are peoples thoughts on this and this
call tom at autopro reynella, he hooked me up with some decent ones with grease fittings for cheaper and within a few hours, i have the tools to split them off the rack and pinion link abe
Should have had a look here first, as I have just ordered a set from Grand Nissan...anyone got spare appendages I can have to pay for them (around $300 for a set, ready for pick up on Wednesday). I am having them fitted on Saturday along with new Tyres, and a Wheel Alignment, Tyres $260 Each, Fitting of Rod Ends & Wheel Alignment $70.
So what IP's is everyone using and what sorta clams they worth a month?? My contract with Vodafone is just about over and i wanna upgrade
If you want all out quota with shit customer service, go TPG. If you dont mind paying a little bit more for quality service, go the Node.
I've got KTS adjustable tie rod ends for an R33 laying around, extra lock etc. Interested?
If you cant have Internode or any other ADSL service at your location like myself; Telstra cable is f**king brilliant - although a little expensive, unless you get a bundled deal including your land line.
but fark me its fast. i wouldnt even bother with ADSL if it were available to me. it would be like going back to dial up!
muahahahaha
* ati balancer
* hks pistons 87mm
* Attkd h-beam rods
* hks step-2 camshaft springs
* greddy cam gear cover
* hks oil pump
* apexi multichecker
* acl race bearings
* grex N1 street special camshafts
$3k
:blink:
should have it on tuesday
then will get tomei gasket kit, hks timing belt, n1 water pump
schweet
cant believe my luck, negotiating all the above for 3g
:worship:
no rush tho, all in good time
heres a quick clip i whipped up of the side pipe and maaaaaad flutterzzzz brooo :worship:
excuse the tinging sound you can sorta hear, thats the cut sunkist can i used to block the rooted wastegate
so it didnt sound like a tractor :blink:
http://s177.photobucket.com/albums/w217/cr...01042010009.flv
i agree so much so
so, just did a roadtrip to bendigo and back yesterday with a mate to pick up a car. not bad for 900 bucks either
N13 SVD Pulsar Vector SSS
http://forum.pulsar.org.au/showthread.php/...ormation-thread
God damn. Over 400 pre-orders for the Nissan Silvia hoodies!
How many of those orders will actually be fulfilled?
BTW whats with SAU? Everytime I post something it takes forever to submit. Is there some new screening process installed that slows everything down?
well boys and girls as it turns out im only 27 and need to have tests for Arthritis in my right wrist i cant belive it it seams 7 years of doing nails has taken its toll
yeh love, Ive had arthritis developing since I was 11.
32 now, knees removed without replacement, 2m tall - takes its toll.
currently on mobility impaired pension. seeing i cant do diddly squat
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
