  • Replies 14.2k
I need new Tie Rod Ends for my R33, and i need them quick, as my car is booked in for the 10th for new tyres and install of the new Tie Rod Ends, before the Track Day. What are peoples thoughts on this and this
call tom at autopro reynella, he hooked me up with some decent ones with grease fittings for cheaper and within a few hours, i have the tools to split them off the rack and pinion link abe
Should have had a look here first, as I have just ordered a set from Grand Nissan...anyone got spare appendages I can have to pay for them (around $300 for a set, ready for pick up on Wednesday). I am having them fitted on Saturday along with new Tyres, and a Wheel Alignment, Tyres $260 Each, Fitting of Rod Ends & Wheel Alignment $70.
So what IP's is everyone using and what sorta clams they worth a month?? My contract with Vodafone is just about over and i wanna upgrade
If you want all out quota with shit customer service, go TPG. If you dont mind paying a little bit more for quality service, go the Node.
I've got KTS adjustable tie rod ends for an R33 laying around, extra lock etc. Interested?
If you cant have Internode or any other ADSL service at your location like myself; Telstra cable is f**king brilliant - although a little expensive, unless you get a bundled deal including your land line.
but fark me its fast. i wouldnt even bother with ADSL if it were available to me. it would be like going back to dial up!
muahahahaha
* ati balancer
* hks pistons 87mm
* Attkd h-beam rods
* hks step-2 camshaft springs
* greddy cam gear cover
* hks oil pump
* apexi multichecker
* acl race bearings
* grex N1 street special camshafts
$3k
:blink:
should have it on tuesday
then will get tomei gasket kit, hks timing belt, n1 water pump
schweet
cant believe my luck, negotiating all the above for 3g
:worship:
no rush tho, all in good time
heres a quick clip i whipped up of the side pipe and maaaaaad flutterzzzz brooo :worship:
excuse the tinging sound you can sorta hear, thats the cut sunkist can i used to block the rooted wastegate
so it didnt sound like a tractor :blink:
http://s177.photobucket.com/albums/w217/cr...01042010009.flv
i agree so much so
so, just did a roadtrip to bendigo and back yesterday with a mate to pick up a car. not bad for 900 bucks either
N13 SVD Pulsar Vector SSS
http://forum.pulsar.org.au/showthread.php/...ormation-thread
God damn. Over 400 pre-orders for the Nissan Silvia hoodies!
How many of those orders will actually be fulfilled?
BTW whats with SAU? Everytime I post something it takes forever to submit. Is there some new screening process installed that slows everything down?
well boys and girls as it turns out im only 27 and need to have tests for Arthritis in my right wrist i cant belive it it seams 7 years of doing nails has taken its toll
yeh love, Ive had arthritis developing since I was 11.
32 now, knees removed without replacement, 2m tall - takes its toll.
currently on mobility impaired pension. seeing i cant do diddly squat
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
