ok update the hot water taps wont turn off in the laundry and i went to have a shower befor the water ran out and got zapped hardcore it made me scream and it hurt my hand my washing machine keeps on chirping and foxtel now wont work
not to mention my ragdoll cat is missing she was put in the laundry to sleep as per everynight with my other ragdoll and she is gone there is no where she can get out
ok thats dangerous. I suggest you call out an electrician ASAP cause theres something not right somewhere
-D
  • Replies 14.2k
ok its not funny, but why are you on here posting about it and not out looking for said cats
i have looked all morning for hours she was in the laundry there is know way she could get out what so ever its like she has vanished
im just more needing to know how to turn off mt tap in the bathroom without electricuting myself again
should be a tap out the front of your house a Mains water tap turn that off and you'll get no more water to your house
i tried that hun but the water is the hot water so it must keep running till all the hot water is out of the tank
the landlord wont be here for a few hours either
my hand is hurting and it had to be my sore one as well
turn the power supply to the house off
then turn tap off
-D
soulns liek a problem that a friend of min had last week.. a water pipe burst inside the wall, and filled the wall cavity with water which came leaking out of the power points :P
+1 to calling a sparky, its not worth yours and your sons saftey to wait
I have a question,
A mate of mine has just moved down to Adelaide from Gold Coast, and he has a VS Statesman with a 355 stroker in it, does he have to take the car to ID check or can he just change the address to south australian rego? I know if you buy a car from interstate you have to stuff around with all that ID check bullshit, but because he has just moved states and not sold the car can he just change it over? He can get a QLD 'road worthy' too by the shop that built his engine
kellie
ring 13 13 66 straight away. thats a broken neutral (as brad and i both thought earlier)
describe it as you got a shock from a tap when trying to turn it off, and a customer service crew will be sent out.
do NOT ring an electrician yet, ring ETSA straight away
i think your right because he isn't swapping names on rego might just be change of address form
even so they wouldn't give a stato too much grief except for 20% tint or something maybe a big ass blower
I'd say the boys at the ID office would slap a sticker on the car - Its absolutly offtap sounds like an animal and tucking 20's.
Cheers for that one, I'll be sure to let him know.
I have consumed so much alcohol this weekend, I am in pain :P
Signed the paper work for our home and land package this arvo
ended up going for this http://www.sterlinghomes.com.au/home-desig...cquarieensuite/
house and land package at munno para west, along with a few extras like stainless appliences, built in robes etc etc
come to 232k
will do me the missus and the little lad for a few years, then rent it out and onto bigger and better :P
just gotta flog this unit off now!, word of advice, avoid northern property world, there useless pricks.
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
