  • Replies 14.2k
RB25 run 9.0:1 static compression standard and have slightly higher compression figures because of that. Of a healthy engine you should be looking for 160-170psi. As long as they are all within 10-12psi it should be fine but with 90 psi you will be down a fair bit on power.
EDIT!!
Here's the figures from my manuals;
1.20 MPa = 12 BAR = 176.4 psi
1BAR = 14.7 psi
Standard: 176.4 psi
Limit : 132.3 psi
Difference between cylinders: 14.7 psi
Edited by D_Stirls
EDIT!!
<snip>
1BAR = 14.7 psi
Standard: 176.4 psi
Limit : 132.3 psi
Ive got between 80 - 92 psi on all 6 lol
need some advise,
the fan that sits onfront of the rad has the mesh around it..
does that need to be connected? mine is running consistanly and is pissing me off..
can i disconnect it?
thats the aircon fan mate, confirming you're talkin about the one thats in front (and by front we'd mean closest to the front of the car) of the radiator?
if so, definitely a/c fan, and its probably still sitting in front of the aircon radiator anyways (have you gone that extensive when the actual radiator was out, and get the other radiator (which tucks in under the rad support panel) out?
i still have all the air con connected.. but i NEVER turn it on...
just in the last week the fan has been on everytime i start the car..
wont turn off so i was wondering if i can unplug it?
    • Yea I could, but it is amusing how shit a stock seat and belt are
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
