semi right Ben
If someone is standing over your bed at 3am and you put him out of his misery, you'd spend a couple of years in court and most likely get off in the end.
Different story if someone is in your shed or backyard though, then it's a case of the "equal or lesser force" rule applicable
Aye I know this, but if someones in my yard and they DONT run then the law be damned. Like you said a few weeks ago, nobody goes to jail in this state. Public opinion on this sort of matter is enough to sway any jury.
-D
  • Replies 14.2k
Yeah i always thought they were plastic till JIS told me they were fiberglass then i looked on the auctions and found they were correct
http://page2.auctions.yahoo.co.jp/jp/auction/b107935204
Only the lips are plastic im sure.
lol good luck with that whole not going to jail reasonable force argument Ben
i almost guarantee if you shiv someone who is stealing your car that wouldn't count as reasonable force hence you loose and we visit you in the big house
and if it really was a "shiv" that would show prior intent to do somebody harm and you may end up on murder but probably dropped to manslaughter with a good QC
we'd have to get permission from his new girlfriend first........Bubba!! ;)
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
