excellent.
ordered brake pads on monday, and was assured theyd be here by today.
guess what?
theyre not here.
and i have a motorkhana and a hill climb coming up.
im somewhat f**ked off. means i gotta spend another couple hundred bucks on brake pads.
money i shouldnt have to spend.
f**kin excellent.
nothing unusual, typical postage service reliability. Or maybe a poor excuse of a vendor.
Arent you selling your car though? Hillclimbs and motorkhana's are the last thing id be doing
  • Replies 14.2k
pretty well.
and yes, i am. but a) ive spent all the money getting it to a point where its a reliable go fast car, and b) the motorkhana and hill climb make up 2 of 3 days ill legally be able to drive my since january and until... november. i think.
and if i still had my licence, id still be enjoying my weekly hills runs. which is probably harder on my car.
Edited by scandyflick
honestly i would say poor vendor, i bought some parts from PC case gear money cleared 21st had parts on 22nd with e-parcel that's a guaranteed up to 10 business days
who said it was to do a DET :)
the DET gods say ;)
I agree with steve. When I ordered lukes 1600cc injectors from florida, they arrived within 5 working days and that was non priority airmail from the USA... no way they can blame the posties unless they got the most basic postal option available - and even then maybe not...
-D
i so had a little lol to my self
Guess
G Shine Clutch Bag
OTFFWN9SL_large.jpg<<click
description should say
'when your the last man on your team holding this bag provides you with clutch leetness'
'take it to your next lan and be the envy of all other players'
'in 2 fashionable colours for men and women'
:blink:
Does anyone no where i can order the part labeled 14875PA
Mine is leaking pretty bad as you can see in the photo.
Cheers
Main North Nissan should be able to get it in, usually theyre not cheap tho
Try koji at jap import spares, he can get pretty much everything nissan can but a tad cheaper (sometimes)
he might have a second hand unit tho... ditto for nisswreck and JMS, they're all worth calling/emailing
-D
-D
you wouldnt happen to no what its called would you?
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
