  • Replies 14.2k
gettin pretty desperate for stock 33 gtr suspension....can anyone point me in the right direction ? Need to borrow it just for an ID inspection (and yes posted it up in the "wanted to borrow" thread, with no luck..)
Hitup Sinergy Motorsport - See if they will lend you a set and or go into Japanese Import Spares - from memory they do hire out items too. Of course, you break it you buy it haha
around 4 months ago; we had to twist koji's arm to lend us a part for 24 hours. Put some dollars under his nose for them to hold on to and he ended up letting us have it, but he was reluctant to as he didnt want to get in strife from his manager
may have a different system in place now though
Pre sale is Friday to Monday on ticketek website.
You need to be a member of ticketek which is free to do online.
They went on sale at 12 noon today and the servers were flooded. Finally got through and at 12:30 gold seating was only in singles and silver seating had to be refreshed about 20 times before they let me go through but standing was all good.
$150 a ticket though but will be very worth it!!
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
