  • Replies 14.2k
http://poststuff3.entensity.net/050710/fla...p?media=dog.flv
HAHAHAHAHAHAHAHAHAAHAAAAA
click on it, you wont regret
**** pls note i am not Damo so it isnt a rickroll :)
put that shit on facebook. funny as.
Very very Nice. Did you need to test that engine in my shell? :P
why certainly kind sir... but i believe that there is a small chance of your gearsets being stripped :)
skwiz.. i wanna make love to your new toy.. thats heaps nice
went to the trouble of taking the 200 around to a potential buyers house tonight, which is no small thing when you dont have a licence and the only other manual driver in the house has recently had surgery on his knee, but anyways, i found a way.
get the car there (out in mile end), park up in the dudes very well lit drive way, and he spends 5 minutes looking around the car, doesnt pop the hood, doesnt look under the car, and doesnt ask any questions.
after hes done he comes up to me and says, "look mate, im a mechanic, and its obvious to me that this car hasnt been looked after, and i reckon its been drifted into a kerb or 2 eh, chuck us the keys and ill take it for a test drive, if im happy with it, ill give you $9k."
dont know what the hell he was expecting with that.
i bet he didn't RoR spewn Dave better luck next time
unfortunately he didnt. :P
he did tell me to get f**ked though, so im hoping to hear from him soon. :)
What movie?
id allow him to skip the dinner if he took me to see twilight. :)
Edited by scandyflick
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
