  • Replies 14.2k
i got the 31 coz it was basically free.....
and id buy your s13 Kye, but i like CA's about as much as i like hepatitis.
i only want RB, nothing else.
I had the same mind back in the day
but after owning one, I rather like them. Sound much better then an SR and done 4 track days and hasn't missed a beat :) plus, it's regod!
f**k it, I'm doing another track day!
yeah and more $$$
f**k it, ill keep sliding the 31, dont care what others say.
eventually it will more than likely come to an end, THEN ill worry about another set up.
Kye, organise a private day!
i cant say iv ever driven a CA, its just the thought of a 4 cyl makes me feel all dirty
I look forward to taking you for a drive to change your mind, Scaring the shit out of you in the process. :P
Edited by D_Stirls
tell them tangles (big brendan- stagea) wants his safc&sitc back that got stolen by troy. :ninja:
I think you need to clarify which troy...its not me..lol
on another note, has anyone here heard how good or used the new BFG tires are ??? thread pattern looks cool and you can get semi slicks and slicks as well ?
and a wallpaper from there site.R34..lol
Not sure if non-FBers can see this or not, but check this out. Loved it.
http://www.facebook.com/home.php#!/vid...v=1218044052737
heh saw that, it was in the youtube thread a few weeks ago, along with the follow interview
good on him
-D
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
