  • Replies 14.2k
Cst's Wayne. I can hook u up a set when I'm bak in adelaide. Currently in a club in Sydney :mad:
We'll talk when your back in Adelaide man :P
Go hard! lol
Edited by Weezy
also have the thought that it was done when engine was cold so pistons and stuff still needed to expand etc..
specs:
Fully balanced
Arp main studs
Arp head studs
Acl bearings
Acl 1.2mm head gasket
Ross/acl pistons
Argo rods
Adj cam gears
Gates timing belt
Has a rb20 exhaust cam on the intake to take the vct off
Was built with all new Nissan bolts, gaskets, seals
Once you have different cams and or adjustable gears, comparing compression results to factory will tell you nothing. This is also the same if you fit a different H/Gasket and the pistons will probably be slightly different compression to the factory ones as well. The difference between the cylinders is what you have to look at but a leak down test is what you really need.
You wouldn't want the difference between cylinders to be more than 10 psi but that's probably not to bad for a cold test.
Edited by D_Stirls
yeh i was reading and found the results not to be too bad..
going to go look at the motor and possibly purchase it.. fit my cams, plenum, turbo etc...
and dale i love my eboost...
would never let it go!
Funny:
Bloody lucky:
:blink:
Brass balls for the bloke. I was at eagle on the hill one day back in 2009 and there was a bunch of hecktik biker boys in full leather on their GSXR's etc racing up and down, in 45 degree heat :\ Crazy kents!
I found out what that grinding noise was, in my drivers side wheel arch. The retaining pin for the hand brake shoe had popped off, and got stuck in the drum, where it started to get ground down. Now to source a pin, and spring.
EDIT: about $5 for a pin and spring from Grand Nissan, so I have ordered 4, may as well replace them all while I am at it, should be here tomorrow or the day after from Melbourne.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
