  • Replies 14.2k
ill take them andrew?!
I have realised this arvo that it seems I can only find 2 of them Adrian. Nigel has them at the moment, but when I get them back they are yours for $10 .... or get them straight from him and fix me up whenever. I will however look for the other 2 - I am pretty sure I hadn't lent/given them away, so they must be here somewhere ....
'Whitey' looked like he had Down Syndrome, def deserved a king hit.
havent seen anyone deserving a decent punch like taht in a while (apart from 95% of the customers that i talk to at work... apparently the world owes all of them a favor)
Heard a few interesting theories about what they want to do to fix it up.
This BP thing is just silly, surely with the amount of off-shore drilling going on these days, you would have a plan to stop this yeah? WRONG!
I say just sikaflex that shit.
or duct-tape, silicone :)
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
