  • Replies 14.2k
So looking at a new phone and im looking at the HTC legend. Anyone heard anything about them or had use of one?? Don't mention iphone to me cause i can't stand apple stuff, even simple things like itunes is a load of wank....
my X1 is still at the repair centre... has been for 5 weeks... must be pretty fkd lol.
meanwhile, just got a phonecall from manager "you new work car has been ordered"
yew!
Spark Silver 2010 Subaru Forester X on its way :ninja:
went thru 3 myself at work, 100% failure rate over a year... screen looses calibration all the time, and lockup when you go into and out of 3G
Imate =failure
Nokia , I dumped those as well , used to be decent now they suck
Sony, 3 failures from 3 top line models in less then 6 months, Optus then gave me a Iphone 3G Second generation, thought I would hate it , but so far so good. only a few bitches since OS4 on it.
if it wasn't free I wouldnt buy one
Blackberry Storm ftw, free unlimited downloads, but only available through Vodafone.
forgot that one,, are they any better then the old ones ? I have a few in a box, DEAD ..lol
common as mud in USA.
best reason for a Iphone is it runs my car alarm ....the module is being certified for use here now..lol of course the car start feature is disable for ADR rules.. grrrrrr
Viper ad
Viper ad
How easy would it be to hack the app and rob cars with your iPhone?
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
