  • Replies 14.2k
Hmmm, boostworks quoted $120. I want to get it checked before I attend any track days.
That sounds about right cause you will fing Shaun usually will make sure everything checks out and will do a few touch ups like he did for me.
Walk in with 160kw rough idle and walked out at 190kw smooth idle and better response.
If you have an EBC he will set that up too!!!
I must admit, I'd get bored after 9hrs to be honest
I would be bored after the first 10 minutes. Me and every other person not on drugs. Hahaha
haha, Mr van buuren would have to be wired on something to stand and jump about in the dj booth for 9 hours
I'd be on the ground passed out or drunk as a viking if i were hitting the bar for that long. But still, i've achieved such status in much a shorter timeframe, lol!
Love the avatar lol - Furio "Stupida-fking-game"
-D
-D
hahaha
Cheers, I started watching the series again a few weeks ago.
Love that scene where Tony sends him into the massage parlour and he gets loose at the asian woman and other owner. Gold!
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
