  • Replies 14.2k
So finally got my HTC phone...After nearly throwing it through the wall a few times on friday arvo i walked away and played with it some more yesterday and must say very impressed with it all highly recomend it! Nearly everytime i go into the menu i find more things lol
board as!
been on the rig 3 days and have done f**k all.
trouble getting the drilling started and i need that to start to do something.
at least im getting paid well haha
Edited by Import S13
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
