that sucks to hear Brendan. Wish I did have time to drop by yesterday. I'm at the hospital atm. Slight training accident. Waiting for xrays. :D
ouch - hope you are ok. glad you didnt come over tho as I wasnt home :) - was wired up to a cardiac machine at the hospital being fed "heart slow down" drugs
  • Replies 14.2k
yeh I know
4 weeks ago I wouldnt have worried about it - state of mind at the time, but now more positive after seeing headshrink / new antideps so figured I better get to the hospital
always had a heart murmur (faulty valve) and an irregular heartbeat but never been concerned about it, more on the mind re: knees
was what youd call a 'small' cardiac arrest, perhaps stress as Ive been stressed out with lose of house, marriage breakup etc
seems my heart is irregular like its got a gummed up spark plug, not sparking correctly
they can go in and cauterize areas where the electrical currents are 'shorting' and fix up that way, so tests to see whats up this week
keep thinking positive dude. with any luck you'll bounce back well from all the dramas lifes got you in at the moment
remember, whatever doesnt break ya only makes ya stronger!
-D
I'm guessing something was changed because i now see the first post of a thread on every page of that thread, How do i turn this off as it is pissing me off.
click 'options' on the top right corner of the thread and click 'standard'.
soooooooo
Ive been in hospital, cardiac unit
had a small heart attack friday arvo
out of hospital now but out to cardiology specialist unit for more examinations soon
heart was over 200bpm for half hour & trying to come out of ribs Aliens styles, left arm went dead, then 130-190bpm for 24hrs
feel pretty ratshit now
anyways, yeah
fullon
yeh I know
Far out Tangles, everything that life can throw at you has by the looks of things......time to look up at the big fella in the sky for some answers me thinks.
Hope all goes well for you bud. :D
thanks guys for the wellwishing - REALLY appreciated, without doubt.
can only go UP from here!
mentally feeling ok - good in the head to be honest, chest is sore this arvo. rest time soon after some chow
then await flinders cardiac unit to call me tomorrow for appointments, probably drop in to GP to let them know the go as well
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
