You're sooo selfish thomas :spank:
I spotted a few lines today!! most memorable was a white r34 this morning ;) the guys said he was from this forum, but i can't remember his nick!!! but :wavey: and i wasn't stalking you!!! lol!!! skyline ass just makes for very good scenary! ;)
also spotted a silver r33 on castle hill road at about 8:30... hehe... i got a grin, and a finger shake?!!? :)
hey moanie ^^ , white car today was me
very clean r33
hmm. maybe i should get a more meaningful nick name lols
edit: whilst i'm here, also saw the following.
black r34 with for sale in liquid paper in the back windscreen @ george street whilst i was doing happy laps last night
red r34 at county drive Cherrybrook last night
grey r34 at the roundabout cnr county drive and boundry this morning
yellow r34 today turning into market city car park
ECL!!!! hahahaha... now i remember it!!! i have the worst memory in the world!!! :spank:
Congrats on the 34!!!! You said you'd only had it for 2 weeks? hehe... bet you still can't get over it!!! bring it out to the next cruise!!!! ;)
as for clean 33?? hahahaha... my car is the dirtiest you'll find around!! :uh-huh:
hahahaha, yer roughly 2 weeks give or take
still trying to work out using the tip
a must do is the next cruise for me =)
very clean r33
hi, would of replied earlier but wasnt able to post. all fixed now christian fixed it.
what time were u driving by on george st & whereabouts?
i was there waiting for a nightride bus between 1.30-3.00 roughly my watch is broken and lost my phone some ****s got it now.
neways
i saw like 20 odd skylines and rexs between milsons point and railway square. also saw the odd 350z roadster s15,rx7,supra,intergra and so on
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
