hahaha... you better believe i will!!!!!!  i'll even steal the guys plates for ya! :uh-huh:  as for ok... yeah.. he seemed like a nice guy... even said he was on these forums?!?!  this was over a year ago though!!!  either way.. hes got nothing on you!!! :D
:D whose 1louis!?!
also spotted a black 34 at strathfield station today.. plates AQR something... :wavey:
Aw..thanks Moanie. Id' hate to come across you in a dark alley!
keep spotting white 33 with BBS's at croydon shops. looks pimp but dude if your out there i'm not gay jus cos i smile and give you a nod every morning. what's with the death stares biatch?
series 1 front bar, with i think a hidden front mount
gtr rear wing, zorst, bov.
guy had a facial piercing
either that or chewing on a piece of metal
Damnit
Whats a guy got to do to get spotted around sydney.
if 5 million cops see me how can not one of you guys/girls
This is :bs!:
Bucket washing is soo stupid. It uses soo much more water. Car wash places aren't much better. Evil ppl, dropping the sponge onto the small stone encrusted floor, then rubbing this on the duco!!!! Or those stupid high pressure places... gah!!
i agree wilch!! bucket washing is such a waste of time!!! and i barely trust car washes! i do end up going to one... getting a wash, then home again to wax and polish myself...
lol!!! repaints are DEFINITELY too pricey for me right now! :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
