i think i spotted mona.. penno rd 6:30ish
saw her head turn to look thru the truck i was going past in the other lane
:) i think that was me!!! are your plates yex something?! i thought it might have been you!!! figured you'd be one of the few r34s in this area :)
also spotted a teal r33 - fob something, a black r32 on kissingpoint rd near dundas... the two occupants were being blinded by the sun!! plus another gray 33 near carlingford court! :)
:P i think that was me!!!  are your plates yex something?!  i thought it might have been you!!!  figured you'd be one of the few r34s in this area :(
also spotted a teal r33 - fob something, a black r32 on kissingpoint rd near dundas... the two occupants were being blinded by the sun!!  plus another gray 33 near carlingford court! ;)
yes t'was me... i wasn't sure it was you.. but like you said.. only a few silver r33's with a chick driving around that area..
]']i saw a R33 GTST S2 white
with the plates UCMOON
and a R34 GTT red 1 out side the commonwealth bank off power road.
yeah who owns UCMOON now? It lived near me until it was sold, now I don't get the pleasure of driving past it every morning!
Just spotted a white R34 GTR M-Spec travelling in the opposite direction to me on Fullers Road in North Ryde around lunchtime. (Im the guy driving the Black R34 GTR)
Very nice car mate - hope you visit the forums - sorry I didnt wave back but I didnt see you until the last moment. I also saw you parked it there for a second a bit earlier (when i was going out to lunch) and slowed down for a look. I feel so bad for violating the code!
Anyway if you do read this PM me id love to check out the M-Spec some day :P
Spotted: BLACK R34 plates MOSTRO or something like that....pretty sure it was a GTR..only had a quick glance. This was near PowerPlay tuesday.
Also spotted today Duncan in HGE-002 at the corner of victoria rd and devlin rd...with the OUCH sticker on the side....hahaha cracked up hard when i saw that....
I was beeping my horn and waving a like a lunatic to grab your attention... :)
Well it was either you Mona or sum other hot chick driving a silver R33 then
hahahaha
:aroused:
lol!!!! it definitely wasn't me then!!! :)
spotted a white r34 gtt in the city... plates GTT 888
and a dark 33 in the superdome carpark.. plates arb something...
GO THE RAZORS!!!!! :)
spotted a balck 33 in QFCL building, parked next to it to go work, but got kicked out cos i wasnt allowed to park there.....sooo then i parked outside and there happend to be another black 33 with fmic and gtr wing...had to park next to it,.!!park with style!~
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
