Me p'raps? Not sure of the day I *think* I was around the area recently. If it was me I have a SAU sticker on the back of the windscreen in which case :wavey:
no it wasn't your car , i know what your car looks like... :P hmm... i sound like a stalker
anyways, saw a nice black 4dr r32 gtst with number plate "5W" in the city in front of capitol theater
Lol
I take the Skyline out and never see any
Take the damn Ford and always see at least one.
Maybe i need a SAU sticker on the Ford
prob cos u're enjoying the car too much while driving:D
sticker - hmm that might be an idea, lol
u'll get ppl asking why u have the sticker though :wassup:
hahaha.. .hey.. i was in my 'line today and i saw a holden gts... plates were MISGTS.. i thought MAD!!!! It was being driven by a hot blonde chick.. i grinned on passing.. she looked... stuck her nose in the air, then looked away!!! what a snob!!!! lol! i was giving some respect to a fellow chick driver and thats what i get! pft!! :)
AS*48I and ZBJ78* (* to censor out details) white and black R33 GTSt's respectively at Thornleigh Maccers today at 9:30 while meeting a few of my Honduh mates.
Also comin back from North Rocks shoppo at about 11pm, dark blue R33 GTSt... gave him a wave and he gave me a rev and raced in front, then screeched his brakes at the next set of lights... hehehe silly boy was in an NA GTS and not a GTSt as I had assumed, should kno better than to take on a slightly modified ceffy... handed him his arse on a plate and then proceeded to stay under the speed limit... then showed him how to control a tailend comin out to play turning right onto penno rd :) hehe go the team super fun happy sliders drift-support-vehicle.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
