]']i was in my SKY white R32 GTR
with plates JDM-32R
i was in the traffic in the opposite lane and u were in the non conjesting direction :)
Sometime before last weekend, were you going through the roadworks towards Castle Hill at the start of Castle Hill Road (Thompsons Corner) at about 2:00AM?
you know, WRX.
crappy, fwd, understeering thing
Im not sure, I might have got the brand wrong, was it a daewoo? kia?
hehehe!!!
yes i also spotted A-HUGE-xxx on the Anzac bridge, top down, wind in the hair - i think i may have even spotted you running your hand through your hair and glancing in the rear view mirror admiring yourself duncan! is that true?!? :wassup:
that wrx was the WRP10. priced halfway between a wrx and an sti, it has sti springs, sti ecu, sti wheels, sti front strut brace and lots of badges! it went really well. most impressed and more importantly heaps depressed that it reminded me of what a performance car was like to drive! :blast:
round 2:30 was driving near a maroon r33 plate was BENTY on penno rd
then about 3pm behind a r32 GTR gunmetal and no wing on kingsgrove rd
and while on kingrove rd i think i spotted Tommy K filling up at the shell servo
or another black R33 GTR
Benty works here @ ibm, he's parked near me before.
megeer silver 33 on pennant hills rd... boundary rd... new line rd... towards dural last night 9ish
white 33 with a huge rear wing turning right on to new line from castle hill rd this arvo at about 6:30
silver 33 on shepherds drive 6:30ish this arvo... even got a thumbs up :)
I spotted a white R33 series 2 parked on Coonara Avenue as I left the IBM carpark. It was parked, had the drivers window down (white number plates, can't remember plate).
That was me parked outside my mates place. :)
Saw a black GTR pull out of IBM as I left. GTR-**X
um..yeap that would have been after my lil run with the curcuit club boyz through OP
where u driving oppostie direction from me?
should have waved :D
]']um..yeap that would have been after my lil run with the curcuit club boyz through OP
I was about 2 cars behind you - this was before I got my R33 so I was driving the family Camry!
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
