hey R34NOS, I think I saw you up at palm beach a few weeks ago with an R32 GTS-T...
the other day I spotted a nice R34 GT-T, white, gold nissan badge on the front down the bottom of the front bar (on the lip) in avalon... was parked next to a Grey WRX Club Spec Evo 3
anybody on here?
EDIT:
also the other week I saw a silver R33 GTS-T Series II getting raped by cops at long reef, saw the cops looking in the car and shit, and the driver looking pretty pissed off... :) was that anyone on here?
Yeah the R32 GTS-T stopped to tell me he's got 500Hp on wheels and he wanted to race me on the road...But my girl was gettin pissed off coz she wanted to spend some time wit me....but it was a nice R32 though..the guy put a RB25 engine in it....looked nice too...
But we stopped on a very lonely road...How did you spot me there with him?? Were you in your car??
Seen a few lines around lately.
Firstly followed a beautiful black R34 GTR 'MADGTR' from Lane Cove to North Ryde last week.
Then yesterday had a clean white R33 GTR pull up next to me on the corner of Herring (I think?) and Epping Rd, opposite the Ranch. Gave eachother an acknowledging nod, and I proceeded to drool at his ROH rims and other aesthetical mods (subtle but very slick!)
That would be paul , bloody awesome car !
http://www.skylinesaustralia.com/forums/sh...ighlight=MADGTR
i saw this yesturday morning
suprised you didnt c me, im always there at that time
I think i saw you today on James Ruse Drive...silver R32 with sticker on the door ..couldn't get number plate ....I was in my lancer and i was gettin l8 for work coz i was in my lancer not skyline ;-)... Also i see every day R32 GTR dark grey driven by a old guy on king georges rd..
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
